(Last Updated: March 19, 2017)
In creating a project or expressing a presentation, a spotlight is used for highlighting information and drawing the audience’s attention to a specified part of the screen. Saying, a spotlight object retains the original brightness within the spotlight shape and darkens the rest of the screen. This creates an effect like we are watching a dark screen with a search light. In this article, I will show you how to do that step by step in ActivePresenter – The best elearning software ever..
Insert a Spotlight
To insert a spotlight, take the following steps:
Step 1: Open the ANNOTATION tab. (1)
Step 2: Click Spotlight icon. (2)
insert-spotlight
Adjust the Spotlight
After that, you will see a spotlight appears in the Canvas, take further steps to adjust it:
Step 3: Resize and reposition the spotlight.
  • Click, hold and drag its green handles to change its size and direction. (3)
  • Then drag to place it where you want to.
insert a spotlight
This oval Spotlight is the default shape that ActivePresenter inserts for you. You can choose the right one for your work by taking following steps:
Step 4 (Optional): Change the spotlight shape.
  • Open the FORMAT tab. (4)
  • Click the Change Shape icon
  • Select the new shape that you like. (5)
insert a spotlight
format-spotlight-2
Step 5: Further customize the spotlight.
If you want to have more adjustments for your Spotlight so as to make it more customizable, go to the Properties Pane and do as followings:
  • Change the Spotlight Name. (6)
  • Change Time and Transition Effect in the Timing and Animations section. (7)
You can also adjust the spotlight Start Time and Duration by dragging the object along the Timeline.
format-spotlight-3
  • Change the Spotlight Style. (8)
format-spotlight-4
Delete the Spotlight
Now, if you no longer want to use a spotlight, just delete it:
  • Right-click it and choose Delete from the pop-up menu.
  • Or just select it and press Delete key on your keyboard.
Pin It on Pinterest
