Choosing Templates for eLearning Courses Infographic
by | Oct 3, 2016
Last Updated On: May 8, 2025
Elearning-Templates-Infographic
When it comes to an eLearning course, the optimization of the template will make it more professional and visually appealing. Using templates for eLearning courses is, definitely, a perfect jumpstart for those who want to set up a course with an accelerated outcome and reduced time spent. So, what are the characteristics that make templates so desirable?
  • Improve productivity: Forget starting everything from the scratch, using e-Learning templates for courses save you a ton of time in deed. It combines a set of slides with a predesigned theme, structure and color which support content including definitions, procedures, and specific presentation patterns. Thanks to that, you can stay focus on what you are going to present rather than how to arrange elements.
  • Make your courses more engaging: As a matter of fact, learners often produce a bad-looking course with non-professionalism. Choosing an appropriate template adds a great deal of visual appeal to your works, supports the content arrangement substantially that calls learners attention.
  • Organize information logically: Without templates, have you ever been frustrated of figuring out how to place different elements of content and pieces of information? Those designing burdens may make creators end up with slides with texts and objects all over the place. Ready-to-use templates can help instructors organize course information manifestly and coherently. You could select a wide range of infographics topics from social media to business area.
Source: Template.net
Here at Atomi systems, Inc, we created ActivePresenter – one of the most powerful e-Learning authoring software for you. We are updating unique features & templates for e-Learning purposes every day and believe that it is the professional tool you need for your e-Learning course. Download the software and test all features for free here:
What to Bear in Mind When Choosing Templates for eLearning Courses
Here are 5 things you should bear in mind when choosing eLearning course templates.
1. Templates that are easy to use
First and foremost, no matter how it looks, a template should always be user-friendly to be navigated effortlessly. In addition, an ideal template should be easy to be customized, altered and neatly arranged at user’s disposal.
2. Templates fit targeted audiences
It’s crucial to get a course that is audience-focused regarding both content and design. You might want to get a glimpse of your audience preference before choosing an appropriate template. Saying, no postgraduate learner wants a pinky and garish template, for example.
After choosing a default template, you should keep your templates updated periodically to meet your audience’s on-going demand.
3. Templates tie with course contents
The fact is that creating any theme’s templates, especially for eLearning courses, needs color, font, size, etc. Choosing a content-based theme enhances the consistent delivery of the course content. Text fonts and size also contribute massively to the overall impression. Some fonts seem to be more soft and feminine while others more solid and somber. So, the templates you choose should always be compatible with the course content.
4. Templates meet particular requirements
The ultimate goal of an eLearning course is to convey and spread information in the most effective way possible. You had better choose a template offering the requisite elements, a wide range of interactions or integrated feedback sections.
5. Customize templates in your own way
It’s not easy to say which template is the best. However, creating a default starting and ending slide is a great idea to optimize your template. You can also add some additional features to customize template use.
Next time when you develop an eLearning course, try to apply these previous five tips to find your suitable templates. Your visual content will surprise students for certain.
Besides, we advise you to read more about our product,  ActivePresenter – The most powerful tool for screen recording, video editing and interactive e-Learning authoring software.
