Try it now
Working with Events – Actions
by | Feb 5, 2018
Last Updated On: March 2, 2020
Introducing Events – Actions
In ActivePresenter 7, events and actions come with objects and slides. For any kind of objects in ActivePresenter, you can add an event (for example, “when the mouse rolls over this shape”), then add an action in response to that event (for example, “display the hint message”). After completing adding events and actions, you can create desired interactive actions for an object. Specifically in this example, the interactive action is created: “when the mouse rolls over this shape, the hint message will appear”. In today’s tutorial, let’s explore this amazing feature, which is extremely useful in creating quizzes, games or courses requiring a high level of interactions.
In older versions of ActivePresenter, you can manage interactions in the Event Editor dialog. From version 7, the Event Editor no longer exists. Instead, you can set up and manage interactions in the Interactivity tab of the Properties pane. There are up to 21 types of events in ActivePresenter 7, some of them are:
  • On Click: Occur when users click an object
  • On Accept: Occur when any accepted Drag Source is dropped onto Drop Area/Drop Target
  • On Reject: Occur when any rejected Drag Source is dropped onto Drop Area/Drop Target
  • On Correct: Occur when users give a correct response
  • On Incorrect: Occur when users give an incorrect response
  • On Complete: Occur when a question is answered or a text box is filled. It is only available when the mode of questions or text boxes is survey.
  • On Incomplete: Occur when the answer is incomplete
  • On Timeout: Occur when viewers don’t respond within the specified time
There are 30 types of actions that an event can take, some of them are:
  • Go to Slide: Go to a specific slide
  • Go Forward: Go forward by a specified number of slides
  • Show Object: Show different types of objects such as shapes, images, audio, etc.
  • Change Object State: Change the display state of an object
  • Start Timeline: Start the playback of the target timeline. This is important when your project has added timelines and you want to use actions to call them.
Note: Each object can have more than one event and each event can have more than one action. Events vary from object to object, which means different types of object can have different types of events. If you want to know more about each type of events and actions in ActivePresenter 7, feel free to take a look at PDF User Manual from page 191 to page 195.
In general, the procedure of working with events – actions is to add events to objects/slides, then add actions to events, and finally and optionally, add conditions to actions. Besides, you can copy, paste, or remove events and actions at ease. Let’s get to know in detail.
Adding Events to Objects/Slides
To add an event to an object or slide, take the following steps: Step 1: Select an object or a slide that you want to add events. Note that you cannot add events to multiple objects at once. Step 2: Open the Interactivity tab (1) in the Properties pane Step 3: Expand the Events – Actions section (2) Step 4: Hover the mouse over the object title and click the Add Event button (3). Then, select one event from the pop-up menu. Add events to objects
Adding Actions to Events
After adding an event to the object, the event entry will appear below the object title. You can add actions to that event easily: Step 1: Hover the mouse over the event entry and click the Add Action button (4). Add actions to events Step 2: Select an action from the action list that pops up. Repeat the procedure to add more actions if you want. the Action list Note: ActivePresenter 7 allows you to add more than one action to an event. In that case, actions will take place in the order that you insert. To change the order of an action, select it and click the Move Action Up button shape_up_arrow_16 or the Move Action Down button down_16 to bring an action up or down one level respectively. Or, simply drag and drop them to desired position.  Step 3: After selecting an action, the action entry will appear below the event entry. You can define further properties of the action. Just click the action entry and take further steps depending on type of actions you are adding. For example, if you add Go to Slide action, you have to specify the slide that the presentation will go to. On the other hand, if you add Show Object action, specifying the object along with its entrance/exit effect is the next step.
Adding Conditions to Actions
ActivePresenter allows you to set specified conditions for a given action. When you set conditions for an action, then the action can only be played if those predefined conditions are matched. To add conditions to actions, hover the mouse over the action entry and click the Add Condition button (5). Events - Actions This opens the Add Condition dialog. The content of this dialog may vary differently. It depends on which type of objects you are working with. Add condition dialog
  • And/Or: Use this to combine multiple conditions in an action
  • List: The type of object to be compared in a condition
  • Operator: The logical operator which is used to compare
  • State: The state of the shape which the current state of the shape is compared with
  • Type: Select to compare a variable with a variable or a value
  • Value: Set the value to compare the variable with
Tip: You can add extra functionality to actions with variables. For more details, see Variables.
Copying and Pasting Events/Actions
Copying events actions can be useful if you need to duplicate the events or actions that you have already created as it saves time and effort. To copy and paste events/actions, do the following: Step 1: Firstly, right-click the event/action that you want to copy. Step 2: Copy the event/action by clicking Copy in the pop-up dialog.
Copy events actions
Step 3: Use the mouse to move the cursor to where you wish to paste the event/action and right-click it. Step 4: Click Paste, then your event/action will now be duplicated in the new position.
Paste events actions
Another way of copying and pasting the event/action is that you can use a keyboard shortcut instead of the mouse. To copy, select the event/action, press and hold down CTRL and then press the C on the keyboard. To paste, press and hold down CTRL and then press V. Note: When you copy an event, all its belongings like actions and conditions will be copied if they are independent of the object or slide containing them.
Removing Events/Actions
In order to delete any event or action, just hover the mouse over that event/action entry and click the Delete Event/Action button (6) or right click the event/action and click Delete. Alternatively, you can click the event/action and press Delete on the keyboard.  That’s how to add events – actions to objects in ActivePresenter 7. Hope that you will find it helpful in creating effective interactive contents. Feel free to contact us if you need any help.
